ZombieRodeo
About ZombieRodeo
- Birthday 04/07/1979
Hove
ZombieRodeo's Achievements
I bought one of those battery isolators but the negative cable on my Voyager wouldn't fit on it
My 2005 GV has been off the road now for 8 months and I have decided I want to try and turn it into a (tiny) camper. Does anybody have or know if there are any diagrams available with all the measurements inside the GV? I would do it myself but the GV isn't kept at my place and it would be so much easier if their were ready made plans for this! I've looked online and can only really find external measurements
mrtibbs reacted to an answer to a question: Headlamp Washer Question
ZombieRodeo replied to mrtibbs's question in Voyager 4th Generation (2001-2007)
From what I remember, they don’t pop up every time... I think they pop up and spray the lights every 3 or 4 times you spray the windscreen. -
Chrysler Grand Voyager 2.8 Crd Starting Issues
ZombieRodeo replied to Adamalzo66's question in Voyager 4th Generation (2001-2007)
I’m always knocking this to the first position when I get out my car! -
I've tried a few different updated discs for the RB3 system in my 2005 Grand Voyager but they all have the same problem, it comes up on the screen asking if I want to update from Ver. AA to AC yet I can't select anything. It constantly freezes on that YES / NO screen. To get rid of the screen I have to remove the disc and turn the engine off for a few minutes. I've tried all the different buttons and nothing will work.
For the DVD Screen, try taking the screen apart and you should find a little metal disc with a small flat side that rotated when you flip down the screen to create a link and turn it on. When I got my GV I found the same problem as you, all I did was reseat that disc and now it’s worked ever since. It might have just rotated a little out of place so it’s not properly lining up.
Flip Down Dvd No Image Or Backlight
ZombieRodeo replied to KJT's question in Voyager 4th Generation (2001-2007)
Mine was doing this when I first got it... I wound up taking the screen apart and the problem was the little metal half circle that creates the connection to turn the screen on or off when flipping the screen. I took it out and then just put it back in and that seemed to fix it. It had probably been knocked out of position a little bit -
My GV failed on the Parking Brake, if you pump the lever a few times that tightens it up too... I made sure to do it before the MOT and it passed straight away.
Washer Pump Compatibility
ZombieRodeo replied to ZombieRodeo's question in Voyager 4th Generation (2001-2007)
It didn’t work the new pumps connectors are a little wider and the casing is a little shorter. In the end I took the old one apart, cleaned up the motor and it seems to work now. -
Dashcam Hardwire Issues
I’m doing it the ‘fuse way’ as I got the hardwire kit with my dashcam and that has the fuse attachment on it... I never even considered doing it another way! -
I have another query now... I got myself a Nextbase 512GW dashcam and hardwire kit. How can I connect the cable to the fuse box as I’m assuming the only one is in the engine. I’ve been ripping my the car apart looking for a hole but can’t find one, I can’t remove the wiper arms as they seem to be seized onto the bolts so I’m a bit stuck now! Has anyone hardwired a Nextbase dashcam using the kit?
The plastic cover for the electrical connectors can be removed from my pump and from what I can tell the only difference between the old model and the new model is the shape of the connector, so I was thinking about buying the new shaped one and swapping over the plastic cover. Yesterday my washers had hardly any pressure and not much water came out, i checked the nozzles and the pipes and they are fine... the motor in the washer pump is really rusty and after cleaning it up a bit (and cleaning the filter bit) I now get no water at all. I’ve checked the fuse stand they are all fine too. -
The windscreen washer pump in my 2005 GV has stopped working but I’m having trouble finding a new one anywhere but eBay, the one I need always seems to be more expensive than the ones for the newer models. The pumps look the same but have a different shaped connector on top... would it be possible to take the top cover off a new one and replace it with the correct shaped connector cover from my old one?
I've just got hold of the 2011 rb3 nab disc and I'm trying to update my system, but it comes up with 'Software update FromVERS AA ToVERS AD' message it will let me choose Yes or No but it won't let me select it... then it just freezes on that screen and I have to disconnect my battery to reset it as ejecting the disc doesn't help. Any ideas?
