GVCamper
47 -
GVCamper last won the day on July 10 2017
GVCamper had the most liked content!
About GVCamper
- Birthday 07/22/1986
Norway
GVCamper's Achievements
Timing Belt Job Diy - 2.8 Crd
GVCamper replied to karmannski's question in Voyager 4th Generation (2001-2007)
Norwegian actually, only know a few swea words in Polish -
What Is Needed For A Cruisecontrol Install?
GVCamper replied to GVCamper's question in Voyager 4th Generation (2001-2007)
Thank you very much, i'm gonna check out the seats. Doesn't look like the cruisecontrol is worth it imo -
I don't know the english word for it but its a locking pin allowing for only one way to mount the gears on the camshafts. These were conical press fit. -
Paranoid Newbie Or Autobox Problem?
GVCamper replied to kelvin's question in Voyager 4th Generation (2001-2007)
After a oil and filter swap on my box it holds top gear/lock up a whole lot better even if it's hilly. -
GVCamper posted a question in Voyager 4th Generation (2001-2007)
My 05 grand voyager was delivered without cruisecontrol and heated front seats and i want both so looking for what is needed to install them? Most importantly cruisecontrol. -
When the thermostat dies next time I suggest you do the Renault thermostat in the front top hose. Andyb2000 has a how to on youtube with links for purchase, makes that job into a 10 minute one and much cheaper. Been running that mod for over 6 months no hassle -
The camshafts doesn't have pins so the blocking kit is essential. Just doing the belt would run you something like 4 hours, closer to 10 when doing the waterpump too. Would personally do both as a WP failure ruins everything. Did mine 6k kilometers ago, not looking forward to next change at 300k kms -
karmannski reacted to an answer to a question: Anti Roll Bar Bush Replacement
GVCamper replied to andyb2000's question in Voyager 4th Generation (2001-2007)
Geting rid of those knocks makes it worth it even in the rain on tuesday I have an inspection so it can be registered with all 7 seats -
GVCamper reacted to an answer to a question: Anti Roll Bar Bush Replacement
bignev reacted to an answer to a question: Anti Roll Bar Bush Replacement
I think Andy is in Britain,it's probably still raining (I'm Norwegian so weather jokes are allowed) -
Hi guys, recently did a audio install in my 05 with 4x Ground Zero 6x9, Power Acoustic amplifier hidden inside dash and some Pioneer 5.25" on top of dash. I kinda decided i wanted to add a subwoofer but not lose the stow and go functionality, anyone had any luck with those under seat active woofers under the drivers seat?
Looks the same as mine, but had it on a lift and they were both accesible from underneath. I cant remember it being nut and bolt either, if not mistaken i just removed the bottom one and flipped it up to remove the old one. -
Mine swapped easily, just removed the end links and put the new bushings on from there. I think i have just the same engine and heater so i can't understand what comes in the way on yours. -
Yeah mine is a 05 btw
Thanks guys, gonna order 5 quarts.
Gonna do a filter and oil change on the 2.8 crd auto and can't seem to find reliable numbers on how much atf +4 to buy. Not gonna flush it as everywhere i read they don't like it. The average of what i find is 4-4.5 quarts, would that be correctly.
