Godefroy
8 -
Godefroy last won the day on February 12 2019
Godefroy had the most liked content!
About Godefroy
- Birthday 01/23/1981
Lymington
Godefroy's Achievements
Sdrew2006 reacted to a post in a topic: Grand Voyager 2.8 Crd For Sale (Faulty)
for sale Grand Voyager 2.8 Crd For Sale (Faulty)
Godefroy replied to Godefroy's topic in Classifieds
Sorry for that. I would like 1000 pounds for it. -
Grand Voyager, diesel for sale. It has two major faults. Fuel pump faulty and has problems starting. Once started though, runs ok. Been to poland 5 times and never let me down. Other fault is oil leak from between engine and gearbox. Some scratches on body. Otherwise, don't know about any faults. If interested please make me an offer. If you want check car details online, reg number is HF55 AVU.
GVCamper reacted to an answer to a question: 2.8 Diesel Automatic Start Problems
Godefroy replied to Godefroy's question in Voyager 4th Generation (2001-2007)
The filter I found is between engine and radiator just under this "corrugated" hose. Silver metal cylinder. Attached to priming pump -
yes. looks like loos cable was the issue. car started ok today. now i need to get fuel filter done. i've checked youtube and internet, but cannot locate filter near fuel tank, the only one i was able to spot was in the engine bay near radiator. ive got 4th generation gv from late 2005. do you guys know if it is the only fuel filter? -
I think I have found where problem is. Will know for sure tomorrow. One of the cables connecting alternator was very loose. Had to push it in quite a bit. Once connected, starter operates much quicker. Next thing I will need to check is fuel filter. Fuel starvation -
No. When I fitted new battery I had exactly same issues. Cranks very slowly and drains battery flat after 3-4 attempts. Once started though (via jump leads) I have no problem with staying it till rest of a day. Until next morning. Mind You last two weeks we had -5 during nights. What concerns me most is how the battery goes flat so rapidly. I had starter motor changed couple months ago could there be some sort of loose connection or lack of grounding? -
Yuasa 12v 75Ah 650A Car Battery YBX3086 (57233) Manufacturer: Yuasa Model: YBX3086 Battery Type: Car Battery Length: 278 mm Capacity: 75 AhCCA: 650ABattery Chemistry: CaCa Car battery Width: 175 mm Voltage: 12v Terminal Style: Standard DIN Posts Height: 190 mm Product Weight: 18.8Kg Terminal Layout: 1 Brand: Yuasa Range: YBX3000 Part Number: YBX3086 Alternative Refrence: 086, 57233 Voltage : 12v Ampere-Hour Capacity at 20hr rate Ah: 75Ah Cold Cranking Performance (Amps) SAE/EN1: 650 Dimensions LxWxH: 278 mm x 175 mm x 190 mm Terminal Layout: Positive (+) on left, Negetive (-) on right ; with the terminals on the edge of the battery closest to you Terminal: Standard Round DIN post http://www.thebatteryshop.co.uk/yuasa-12v-75ah-650a-car-battery-ybx3086-x2857233x29-8830-p.asp -
Godefroy posted a question in Voyager 4th Generation (2001-2007)
Hi. Recently i started to have major issues starting my voyager. what it does, when i turn ignition key to start the engine, the starter motor works (slowly) but the engine fails to start. repeated it 3-4 times, and drained battery. when i jump started the car, i didn't have any more issues till next day. Again, 2-3 tries, battery dead, jump start and off it goes (i need to add, that sometimes it takes about 30-60 minutes, and many tries to actually start it). So bought a new battery, but even with brand new battery fitted, i had same problem the following day. Also, don't know if it is also part of this problem, but my car tends to die when i either suddenly brake or accelerate hard (not always but often). What i have also noticed is, when i try to start a car, the starter engine works very slowly, but once on jump leads it turns much faster. Please help me resolve this issue.
