scotsholme
    17
scotsholme last won the day on September 15 2024
scotsholme had the most liked content!
About scotsholme
  • Birthday 11/10/1956
    teeside
scotsholme's Achievements
  1. Hi . On 2.5crd 2006 voyager My high pressure power steering pipe is spurting fluid out and it needs replacing. Is there any videos on here showing the removal of the pipe because it looks like a major operation as one end goes up the back of the engine and in a awkward place to get to . Please help . I don't think I could even make it to mechanics 30 miles away.
  2. Thank journey Richard M. I have sorted it no problem with the code . Thanks
  3. Hi . Can anybody tell me if there is a way of changing my battery on my voyager2.5 crd 2006 without losing the the radio code. I have had the car from new but have no got aclue where the radiocode is . Thanks
  4. Thanks for that offer. But I think I have sorted it.
  5. Hi guys . Can anybody help. I have a 2006 crd with that stupid clockspring handbrake. My cable as snapped at the joining piece on the drivers rear side . But the cable is still tight leading up to the handbrake mechanism and I can't pull the cable back to give me some play and I have tried to get into the handbrake mechanism inside the vehicle but because the handbrake does not come up very far I cannot get the cover of . Any ideas how I can get some slag so I can lift the brake handle up so I can get the cover over the handle. Thanks
  6. Where is the maf sensor located on a 2.5 2006 2.5crd
  7. Hi all. Could you tell me if the brake calipers on the rear of a 2.5crd voyager 2006 are the same on both sides. Thanks
  8. Can anyone tell me If there are any links on the forum about rear handbrake cable replacing on a 2006 2.5crd manual. Thanks guys.
  9. Hi all. The back brake retaining pins hole is rotton on my 2005 voyager and it is a big job and expensive to replace the back plate .As anybody got any ideas how to adapt them so ican fix the retaining pins safely. Thanks in advance.
  10. Hi all. It looks like I have a power steering fluid leak is there any links to changing the pump ,I am only presuming it's the pump because it is in that area on the ground and I am getting a labouring noise when I turn the steering whilst driving.
  11. Thanks for all your input guys I sorted it found a wire that had split some how, joined it and alls good . Thanks again for all the help.
  12. Thanks for your feedback. The bulbs are ok and the side light come on and the headlight on the off side ,so I am thinking the switch maybe good so maybe it is the wiring feed.i was wondering if it would be possible to join the bulbs up so they work in series .
  13. I have a 2.5 crd 2006 Nearside headlight and sidelights not working but main beam is there a seperate fuse for the side and headlight as I cannot find the fuse for the headlight can anyone help
