Shanless
14 -
About Shanless
- Birthday 08/25/1958
Northern Ireland
Shanless's Achievements
Thanks guys... Sorry for not giving you more information It's a 2005 2.8 The car drove perfectly...then the instrument cluster failed..no lights or speedo but drove grand I changed cluster but still didn't work I drove the car to a garage to get diagnostic done I might as well have pissed to the wind cause they were crap When I went to collect car it wouldn't start It cranks over very strongly but won't fire up I got another guy to look at it and that code came up
Car is reading a fault code P1651 and won't start.... any help much appreciated Thank you
No Dash Instruments Working
Shanless replied to Shanless's question in Voyager 4th Generation (2001-2007)
QinteQ...thanks for your reply I tried two BCMS with same code..the guy I got the from said that they wouldn't need programmed...he let me try them to see if it fixed the problem....thank you the offer of reading the BCM..but i live in North. Ireland Thanks. -
I have explained the symptoms of this my other post "Central locking issues"
Hi Guys...sorry I'm only getting back to this now as Iwas in hospital for an operation.... Update as follows Charged the battery.. Have no dash instrument lights nor instruments working...I've tried two BCM'S..tried another instrument dash..took out fuse box and disconnected all the pugs, cleaned and refitted them...still no dash. Nothing works until the key is in ignition and turned to the on position ( dash doesn't work at all)... Haven't found any isolator Thanks
I unscrewed the isolation unit...no change...tightened it up again.
Just noticed that the air conditioning pump has been bypassed...not sure if its related to the problem
Hi bignev...you are correct....nothing lights up ...including side lights...until I put key in ignition and turn to on....just another thing..the gauges flip when turned to on..don't know if this is related tho.
No Gordy..have to central lock it using switch in drivers door panel...then locking drivers door.
There is a "turn" knob on the battery terminal...the radio doesn't work at all and dash stays lit for a few seconds then go off....I tried to upload a photo but can't.
Hi bignev... I took the fuse out for just over an hour...no change.....puzzled!!!!!!!
I have a 2005 Grand Voyager 2.8...the Central locking will only work from the fob when the key is in the ignition and turned to the "on" position....I have taken the leads of the battery and waited 10mins before replacing them..no change......I've taken out and replaced the IOD fuse..no change....hopefully someone will have a solution for this....PS.alarm doesn't activate either. Your expert advise would be very much welcomed. Thank you.
