Josboogz
54 -
8
Josboogz last won the day on September 29 2020
Josboogz had the most liked content!
About Josboogz
- Birthday 01/01/1980
Josboogz's Achievements
Thanks DeltaMike, that was really useful. Finding the specific part numbers quoted is difficult but went with shop4parts and went with the supplex and quoted for the Bravo 2007* which seemed to match specs on the part number. what turned up were KYB flex picture attached.y local mechanic fitted and the ride height looks good. The previous springs were 2 inches too short. Therefore either these were rear springs or the wrong part incorrectly sent. Hope this helps others. Not many details owners left now :( IMG_2030.heic
Josboogz started following Air Con Ticking Noise and Coil Springs Too Low
Hi, Is anyone else’s Delta very low at the front after coil spring replacements? I have replaced the springs numerous time, first with original Delta springs which were very expensive £178 a corner and then subsequently with Bravo springs which were much cheaper. Although I believe they vary in length so maybe I went for the smaller options available? However, with the Bravo springs the car is very very low. As low as Lamborghini! Anyone experienced this. My mechanic suggests it’s the springs that correlate to the height profile. Dampners and Shock absorbers all ok. He mentioned it could be the tensile strength of the springs of the bravo not being strong enough over time for the heavier Delta? Any advice or suggestions on springs to buy or things to check welcomed.
Hi has anyone has experience of changing the fuel filter and worth doing? if so do you know where to get hold of one and cost of labour to fit? I noticed it mentioned it should be changed at 70 and 140k. I think my deltas are due another cam belt change, manual stating every 4/5 years. what are people’s thoughts on changing spark plugs. I did it a few years back but didn’t notice any change. Thanks,
Hi all, I’ve noticed my air con/ heating in my 1.4 SR had developed a ticking noise. Seems the frequency of the ticking increases with fan speed. When the fan is at max speed it becomes more of a vibration noise. Anyone had similar issues? Any advice appreciated. Thanks
Similar issues with both of my Deltas. Heat shield is not a MOT requirement, mine passed without them. I secured the rattling back box with wire which still holds today. Keep an eye out for Bravo back box sales as deltamike says, found one for £36 and replaced it. Mechanic mentioned that the brackets were a little high but were easily bent to hold the bravo back box without issue.
Hi Alan, unfortunately a sign that all the LEDs are still operational prove the jfault is not the light unit. My light was the same, it wojld go through periods of working when it was locked via the alarm and them eventually started malfunctioning more often. The solution is replacing the light unit. hope this helps
Hi All, Just if it’s of any use - there is a lancia delta for breaking on eBay which has the various lancia badges etc if anyone is attempting to rebadge their delta from Chrysler. Or useful for any other parts. Listing is here. https://www.ebay.co.uk/itm/164651882740 Hope this helps someone.
Cheers chaps. Yes that Alfa is amazing!! Can’t see why you regret that sale. Will keep those unipart recommendations in mind.
Cassino reacted to a question: Brake Pads/discs Recommendations
Cheers Mikey, My Indy did say sometimes it’s luck of the draw on the Manufacturing of brakes with the fit and they squeak until they settle down. You had a TBi sport wagon! Awesome! How was the boot space compared to the delta? I am still tempted to buy one but it’s crazy money for a car 5–6 years older than my delta and double the mileage. I loved my 156 but it always has some niggles which I don’t miss especially with a family to transport about.
Hi All, Just wondered if you guys had any brake disc/pad recommendation for the Delta. My last set were Bosch Pads/discs sets (I was under the impression it’s always best to buy same brand discs and pads for compatibility) and haven’t been too pleased. They have squeaked from day 1 and my Indy said copper grease was no longer needed on the new pads or discs these days with spacers and padding provided but I disagree. My Delta is a work horse carrying 3 children and heavy car seats so is heavy on brake use. Carparts4less have Pagid, Eicher Or brembo. I’m tempted with Pagid as they were good on my golf back in the day. Any recommendations and advice welcome Cheers
Deltamike reacted to an answer to a question: Couple Of Goodies
Just went out to check the connections and the bolts holding the light in the boot and had a fiddle. Looks like a plastic type hex sleeve holding It on? Checked it again and it’s working! Umm.. italian electronics! Will keep an eye out for a lamp as I am not holding much hope. Will keep an eye out and see if it’s intermittent or as per deltamike said connection was loose? Definitely up for delta meet Nello! Prelockdown did you normally drive on the leamington road towards Ryton? I always passed a grey delta on my way to work!
Nello reacted to an answer to a question: Failed Rear Led Light Indicator
Just to keep you posted Grays in Warwick and the other Fiat Dealers have a single light Unit at as £246.16 so shipping via Germany is the cheaper option at the moment
Thanks Nello, that’s helpful. Yep I’m in Rugby, so will do a ring around and get a feel for the prices tomorrow and report back.
Thanks for the helpful comments. Will give the fuses a check on the weekend and report back. I have found one online from Germany for £150 delivered. Not seen anything on eBay, are they generally preowned? Any ideas the going rate on these Rear light units? I think an old post is someone found one for £60 from Italy?
Fantastic idea, looks great! Probably as rare the Delta in the UK!
