mikebh8
592 -
26
mikebh8 last won the day on August 29 2018
mikebh8 had the most liked content!
About mikebh8
- Birthday 09/30/1981
dorset
mikebh8's Achievements
Workshop Manual 06 2.8L Stow N Go
mikebh8 replied to ryden's question in Voyager 4th Generation (2001-2007)
Try this one. http://www.fileshare.ro/e3427297372 -
Hi, coming from a long absence. I don't know if I was the only one posting the link to the chrysler's manual but when I did, I downloaded a copy of what I needed. I've uploaded more links to the pdf files, the manual is for 2004 model but I suppose they are the same. Let me know if the links are ok, it does not require any password or login details. P.S. I now own a 2003 2.8 voyager, 2004 2.5 grand voyager both manual, a 2007 stow&go 2.7 auto and I am thinking for the future to get the new one also... http://www.fileshare.ro/e3427296263 http://www.fileshare.ro/e3427296265 http://www.fileshare.ro/e3427296266 http://www.fileshare.ro/e3427296267 http://www.fileshare.ro/e3427296268 http://www.fileshare.ro/e3427296287 http://www.fileshare.ro/e3427296288 http://www.fileshare.ro/e3427296289 -
QinteQ reacted to an answer to a question: Front Handbrake Cable Problem...
BumBle02 reacted to an answer to a question: Oh Dear Injector Hit By Piston (Yup!)
BumBle02 reacted to an answer to a question: Oil Pressure Warning Light Been On For 10,000 Miles
BumBle02 reacted to a question: Grand Voyager New Shape Key
Daneinsane reacted to an answer to a question: Engine Oil Thrown Out Through The Dipstick
legonsuk reacted to an answer to a question: Fault Code Reader
That's the one, just look for the year as the newer ones look the same but they come with newer year models. Mine is only up to 2014 for example. No need for extra software, windows firewall and antivirus turned off and it should work.
Are you sure the brakra and clutch share the fluid, on mine is a closed circuit on its own?!
2.8 Crd Auxiliary Belt Noise
mikebh8 replied to bigdave's question in Voyager 4th Generation (2001-2007)
I had it on a different car, try removing the belt and check for the tensioner if it is loose, in that case the third is gone on the timing cover where the bolts goes in. Try with some thread blocker. Hope it helps. -
Is it only on first, when changing second or onwards doe it work if you push it half way down, when overtaking, is it revving like it would be on neutral. Hydraulic either works or not there is no in between, could be the bearing. Hope it helps.
dmbeale reacted to an answer to a question: 2006 3.3 Gv - P0344 Camshaft Sensor Problem + Dvd Screen Prob
mikebh8 replied to dmbeale's question in Voyager 4th Generation (2001-2007)
Hi, the P0344 code is also related to starter motor and/or starter circuit. DVD screen not working there was a post about it here somewhere, is a connection at the back of the display. Hope it helps. -
2.8Crd Injector O Rings
mikebh8 replied to Stiglar87's question in Voyager 4th Generation (2001-2007)
Some will do some not, I found on a Mazda 6 that did not came with. It help preventing for building up dirt moisture at the injector's end. -
The ones that are in the middle right after the cooper washer from the bottom way up, I don't have a third one. What do you mean by "leak off pipe", the return pipe? I didn't replace those ones. -
I bought a plumbing box with all sizes and they fit, the rubber washers are there just to protect dirt water and other bits going to the injector's head. I have them fitted for other a year now and is no problem. Hope it helps. -
Hi, I took one from a chrysler that I scraped, just for having an extra point omy roof. It was different than mines, but it fit inside the slide. The only thing I noticed the front is one way only because of the way is narrower on one side for the wind, for a while I didn't know whyvthey were making noise. Hope it helps.
Hi, I use a Delphi 150e and goes around 40-50 pounds now, I am happy with it, used it many other makes and models, found ABS faults, DPF regeneration, component testing and more. Hope it helps.
Hi, have you checked the wires to the CKP. Download Autocodes app and you will get details of the fault. On my autodata to test it says with plug disconnected, you should have 886ohms at component. Another test that I do is: Removing the glow plugs, ignition on, turn the engine by the crankshaft with meter probes connected in parallel to the sensor, you should get an intermittent reading ohms and/or voltage( I'm not sure what the measurements are) but it shod fluctuate. Hope it helps.
300C Wheels Onto A 2004 Grand Voyager
mikebh8 replied to San's question in Voyager 4th Generation (2001-2007)
Hi, I had them fitted on mine, I sold them long time ago, the only thing I can remember is that the spacers are two thinner for the front and the other two a bit wider. Hope it helps.
