Jetfiremuck
12 -
Jetfiremuck last won the day on November 22 2016
Jetfiremuck had the most liked content!
About Jetfiremuck
- Birthday 10/31/1960
Jetfiremuck's Achievements
I put a set of 225/70/16. Completely different van after. Smooth
I up sized to 225/70/16. Big difference in ride quality. No more scraping at kerbs
legonsuk reacted to an answer to a question: Hand Brake Shoes
Pull the rear disc. I'd suggest you get the hardware kit as the adjusters seize and may wear the star wheel. Easy enough to do. They rarely get any use with an auto trans. Got mine at micks garage online
Got fed up of catching the front lip spoiler on kerbs when backing out, and found the clearance in general was too low worse with a load on. Iv an 06 grand limited. The difference is noticeable. Slight rub on full lock but really drives smother with little wallow. These are a 109 rated tyre I think
2001 Grand Voyager 3.3 Transmission Type
Jetfiremuck replied to jason1883's question in Voyager 4th Generation (2001-2007)
Think you should check why speedo isn't working. May be the issue -
Longer wheelbase vans only come with stow and go.
Check for 12v at the compressor plug and a good ground on the other terminal. If both are ok you can try and if careful enough use a screwdriver to push the clutch in while ac is on. If it pulls the clutch in then more than likely you have a weak coil.there should be a gap between the two mating faces ( the thickness of a business card).
Gearbox Service 2.8Crd Auto
Jetfiremuck replied to Dazandtrace's question in Voyager 4th Generation (2001-2007)
Don't know where all the info is coming from. The 41te trans has been around for a long time with obvious upgrades and refinements as timewent on. I replaced my fluid with comma mvatf. It's fully synthetic and works the finest. I've replaced the trans fluid as well. I change every 50k miles. No problems no shudder. -
Self-Levelling Suspension?
Jetfiremuck replied to ZombieRodeo's question in Voyager 4th Generation (2001-2007)
The shock diameter is larger than standard shocks. I have them on my 06 limited. -
nathanevans reacted to an answer to a question: Grand Voyager Engine Cutting Out
The headlight shape was changed is what I consider as the difference.
Diesel Starting Issues - Have Your Injectors Checked
Jetfiremuck replied to Sheen1's question in Voyager 4th Generation (2001-2007)
Before you do injectors. Pull electrical plugs from fuel filter housing. Pump primer to make sure it's hard. Inspect socket for wetness or leak . If leak found filter housing is letting air in and causing loss of prime. Part numbers are 68043086AB wiring kit and 68043089AA filter housing. There is a tsb in the USA concerning this problem up to 07 model years. -
Jetfiremuck replied to Sebetts72's question in Voyager 4th Generation (2001-2007)
Check fuel filter housing where primer is. Fuel heater overheats and distorts housing letting air in. Need to replace parts and new wiring pigtail kit. Part numbers are 68043086ab wiring kit, 68043089AA housing assy. There was a tsb in the USA regarding the diesel liberty and from research problems are possible up to 07 model year. Hope this helps. To check. Remove 2 plugs on top of housing. Press primer until hard. If any fuel residue or wetness is in the socket housing then it needs to be replaced.
