Nello
    913
    57
Nello last won the day on July 6 2020
Nello had the most liked content!
About Nello
  • Birthday 07/30/1969
    Coventry
  • Interests
    Anything Italian........... ;o)
9126 profile views
Nello's Achievements
152
  1. Nello
    Looking To Buy
    ...and yes they were built in Italy as the Cassino plant - where the Stelvio and other current Alfa's are made.
  2. I think I'm on 77k now!....still under average for a 9 year old car.
  3. Nello
    Fiat Porkies?
    You can ask a Fiat dealer to get hold of Lancia Parts for you but they will not do any service work. Best to get an Indy to look at it - try Paul Gilbert in Birmingham if you are in Staffs - right next to the Bullring - he looks after my Delta. http://www.motor-mech.co.uk/index.asp
  4. nevo as per the double post reply - looks like its Punto and a simple swap
  5. When you say you pushed in the boot clasp what do you mean? Does the lock appear 'open' now - it may have stuck in the locked position
  6. So yes its a Ltd then - NMN should do it............ you may need to hold in place for it to bond depending on how much stretch it takes to pull back in.
  7. Presume thats a Ltd with Leather Dash? No More Nails would do the job.................
  8. Yes there are just x2 Hex plastic bolts holding the whole thing on. Insert an Allen key and the light can be removed. There is only one connector - mind it doesn't fall out. Very easy and worth doing just to remove all the gunk that sits in the light edge. May be working now but once it starts to go I think you'll find it'll happen again. Its a common issue on the Delta. Grey Delta not me - mines a white with black roof SR but I do go that way on occasion. I'm in Earlsdon not far from Warwick Uni.
  9. I'll keep my eye out for any Jos - did not realise you were so close to me! Midlands meet once COVID ends perhaps!
  10. £150 is about right. Normally a fair few from Italy as long as they agree to send to the UK. I did manage to get a used one for around £75 from Germany but only because there is a very slight chip in the plastic at the very bottom. Still sealed and works perfectly though so I was happy. No issues since. Jos are you in the UK? Always worth checking if we can source the Part number ordering via a Fiat Dealer. They will get anything as long as you have the Part number. I have used Grays in Warwick and Research in Nuneaton for this.
  11. Yep common problem. Once an LED goes its time for a new light unit. They are sealed units so unless you want to go to the trouble of breaking it open somehow (not even sure how) you'll need a replacement. On a brighter note - As per Mike they are a doddle to remove/change.
  12. Great job! Get us one!
  13. Nello
    Springs
    Which engine do you have Delta123?
  14. Dido is that you Ahmed on the FB page? Just saves me posting again on here!
