Udtrev
    139
Udtrev last won the day on June 10 2015
Udtrev had the most liked content!
About Udtrev
  • Birthday 12/12/1958
    Weybridge, Surrey
3005 profile views
Udtrev's Achievements
10
  1. Hi Nidge, and welcome, This is the remote my Neon had - http://www.ebay.co.uk/itm/CHRYSLER-3-BUTTON-04759011AC-REMOTE-CONTROL-KEY-FOB-ALARM-GOOD-WORKING-TESTED-/261833894184?pt=LH_DefaultDomain_3&hash=item3cf6842928 Is it any good ? Regards Trev
  2. Hi Dave, Sorry to here of your problems, silly suggestion time, can you get it to a Timpsons ? (they can do the blippers too) Secondly sorry but, yes, the bloody things are that expensive, I died when I got a quote for my Jag (the wallet ran away and I haven't seen it since) Trev
  3. Hi and welcome Have you changed the leads as well as the plugs ? Secondly have you been able to read the codes from the OBD system ? Regards Trev
  4. Is there not a slot where a flat bladed screwdriver can be used to work the cover out ? (There often is such an animal on these lamp housings) Regards Trev
  5. Udtrev
    Gallery
    Hi, I've sent Ben a message asking him to help Regards Trev
  6. Good luck !! Can't you look over the border in Devon at that one at Slapton Sands - joking by the way the memorial needs to left alone Is the engine used in other vehicles ?
  7. Hi, The cheapest deal would be to look at a breakers yard to supply one Hopefully they will give you a good deal so you can keep your pride and joy Trev
  8. I cannot say for certain with the Voyager, but the first port of call would be the fuel filter. If you are lucky emptying it will solve the issue, the next step would be to look at changing it. Trev
  9. Udtrev
    Hi, Welcome to the forum, make yourself at home and have fun Trev
  10. Hi, Welcome to the forum, make yourself at home Trev
  11. Saw this in another forum, the 9 speed ZF boxes used by Chrysler, Jeep, Acura, and Land Rover appear to have issues; http://blog.caranddriver.com/holy-shift-zf-9-speed-automatic-problems-mount-chrysler-releases-third-software-update-for-jeep-cherokee/
  12. Welcome to the forum Bob, make yourself at home Good to know I'm not the only Jag owner here (S Type 2.7 disiesel)
  13. Hi, Have a read here = http://www.cargurus.com/Cars/Discussion-t4222_ds548069 and check fuse #13 in here - http://ww2.justanswer.com/uploads/tracker40/2010-07-05_113825_1.gif
  14. Hi Gursel, Welcome to the forum, make yourself at home
  15. Hi, no clue if that will work, otherwise could you not try Timpsons, you might get a better deal than from a main dealer. Regards Trev
